Billy54's avatar
Billy54
Dash A/C Blowing HOT air after engine is hot
2002 Holiday Rambler Class A - Workhorse 20,000 miles.
DASH A/C BLOWS HOT AIR AFTER ENGINE WARMS UP.
So far I bypassed the heater hoses with valves.
Replaced : New AC Delco compressor, expansion valve, expansion drier and 2 new switches which were hard to find since the compressor switch is out of production,but my Chevy dealer found one at a warehouse for me.
I evacuated the system, check for leaks with machine (I have a shop) and we charged it with 2.75 lbs of freon. It worked great - a/c was ice cold. Week later went on a trip - and after 3 hours of driving turned on the a/c to see if it was cold - it blew HOT AIR and never got even cool. Got home, After we unpacked I waited about 3 hours and tried it - now the engine is cold and the A/C blew Ice Cold. Don't get it- why would it blow hot air only when the engine is hot and the heater hoses are bypassed with a valve - and blows cold when the motor is cold?? Can these bypass valves go bad? I used them all the time and never had one go bad on me. I am thinking of taking off the bypass valves and just making a loop with the heater hoses. Also above the heater hoses was a switch - I disconnected it to see if maybe that was causing the hot water to flow past the bypass valve if that is possible.... We are going away again in 2 week and could use the A/C.. Any ideas? Also is 2.75 lbs enough?? I called Monaco and one tech said 2.75 and another said 4 lbs/ Workhorse said that it has nothing to do with them. There is no label that has this info on it on the parts. It is a frigette.
