MrWizard
Jul 23, 2018Moderator
it should be noted 'gas' engines use manifold vacuum
diesel engines, use 12vdc vacuum pumps 'usually' mounted under the dash
and yes you can use a vacuum pump and cap the engine vacuum
but you still need to find and fix the leak
whether it is a bad vacuum line (hard plastic flexible tubing)
or the vacuum storage container
