bluwtr49
Nov 01, 2016Explorer II
Dash AC Question
Quick question regarding dash AC.
My system high side pressure is ruining a bit hit...(slowly rising to ~350 psig at 90F) so I'm thinking I will evacuate the system and pull a good vacuum for a couple of hours than refill. I'm doing this in the hope that I might have some moisture in the system causing ice crystals in the TX valve.
My question is: will I need to add/replace compressor oil when I refill with refrigerant? And, if so, roughly how much?
Any other thoughts about what to look for?
