Ivylog
Apr 14, 2017Explorer III
crasster wrote:
Really - while you can DIY recharge, it is BEST if you can put the system under a deep vacuum then charge. It's the proper way to get all the air out so there is more pure 134a.
Really, How is air going to get into a system that is still cooling, but not as cold as normal... is still pressurized and has enough freon in the system to work somewhat? Even while working the low pressure side will have 60+ psi in it... how is air going to get in???
38,783 PostsLatest Activity: Sep 10, 2026
