lfeather's avatar
lfeather
Dash air
My Dash air hasn't been very cold lately so I tried servicing it with 134a freon that I bought at Walmart with gage. The initial pressure reading was below 10 psi at 75* ambient. The gage says I should see between 35-45psi. I put in one 12oz can of leak stop freon and several 12oz cans of 134a freon. When the gage got up to about 35 psi, the compressor clutch would intermittently stop and start and would sometimes make a screeching noise like metal on metal for a couple of seconds or so, while turning slow, then turn off/on, for a few times, then start turning at regular speed. Then start this process all over again. I thought maybe there was too much pressure or something, (inaccurate gage?) so I released the pressure down to 25 psi and the compressor clutch stopped doing this and the dash air is now cold. Does anyone know if too much pressure can cause the compressor to do this? Thanks for any suggestions.
Larry
  • jfkmk wrote:
    Larry,
    First off, you just did something illegal that you could be fined for. You cannot release any kind of freon, including 134a into the atmosphere. It must be captured.
    Why then are AirSoft guns allowed to use 134A as a propellant? Some spray cans do similar.
    Air Soft Gas
    I suspect the rules you quote are for discharge of 134a into the atmosphere by shops who discharged the gas in high volumes and charging for the service, not the one-off vehicle owner.
    Golly-Gee, if I lose 134A due to a leak, am I going to pay a fine or go to jail?
    Or.....is a leak OK but disharge is not? Help me understand the jeopardy we are all in.
  • Ivylog's avatar
    Ivylog
    Explorer III
    For a system that is cooling but not well one can of Freon should be enough. Several more cans was way too many cans of Freon.
  • Sound like you got a liquid lock, If you turn the can upside down or on its side it will put in liquid and on the low side that is a no-no.
  • Larry,
    The compressor will not work properly on too high a pressure. I'm not sure exactly how it acts when the pressure is too high.
    Next time, you should go to a repair shop where they will perform the work properly and legally.
