jdl2197's avatar
jdl2197
Dash alarm when power to house and ignition is on
Hello. We just purchased our first RV, a 2003 Coachmen Pursuit. There is an alarm at the dash that activates when power is on to the house and the ignition is on. What could we possibly be doing wrong?
  • Did it do that when you looked at the RV before purchasing it? Have you used the RV before this and that alarm did not sound? There are a lot of things that can cause this. The most common would be the Jack leveling system to level the Motorhome. Most Jack systems have some type of light and alarm that will sound if the KEY is ON and the jacks are extended. If you have Jacks and they are not extended, there could be a fault with the Jack system. You need to state what Chassis you have Ford/Chevy/Workhorse. Doug
