Fairgrove's avatar
Fairgrove
Dash gauges low voltage problem
My voltmeter has been reading low voltage for some time. I removed the meter and hooked it up directly to the battery and the reading was good.(13.5v) I then reconnected it and ran a new line for a direct ground. Still low voltage. (11v) The power to the voltmeter is daisy chained to all the other gauges. I removed the line going downstream from the voltmeter but still llv. The power comes from my front bay fuse terminal block. If I remove the connector that supplies power to the gauges it reads 13.5v. I ran a wire direct from the fuse panel to the voltmeter and it reads 13.5v I know I have a drain somewhere but it is near impossible to work behind the dash. Any ideas???
  • Pulling the dash is the last resort. Between the 15 switches, air lines, radio backup camera, speedo and tach, a/c controls and vents and hundreds of wires I am not looking forward to that. Plus it is made out of that phenolic material that cracks and breaks easily.
    Dan
  • Yep, dash work sucks bad. No way to remove the cluster area or just get it to pull out some?
  • I did run a new temporary ground and it did not help. My electrical schematic does not show any relays in the gauge circuit. I cannot look up from below because the way the dash is made. I do have an access hole from above but it is very tight and there is a great number of wires.
    Dan
  • As hott said, see if its running through a relay. Also check each point that the circuit connects to. Its got a poor connection at one of those areas. If you can look up there with a mirror and flashlight look for dark areas on any terminals or multi pin connectors. Some times you can reach in and touch different ares one at a time while watching the gauge for movement. You may also feel hot areas.
  • Run a new/additional ground from the ground side of the gauges. Remember, the electrons must make the ROUNDTRIP to the battery, not just from battery positive to gauge positive.
  • I would check the power relays and see the voltage drop accross them. They arc and have a bad connection
