JRscooby
Mar 01, 2020Explorer II
dougrainer wrote:
1.You appear to have a 15 year old unit.
2.Dash Heat will be in the 145 to 165 range on a Diesel
3.It is not uncommon on a unit as old as yours to have a clogged Water valve restricting the volume of hot water
4. You need an actual temp measurement of the hot air coming out to determine if you have a problem. Doug
Also need to compare temp of hoses at both ends. Might be loosing heat because the hose runs thru cool area, or because of limited water flow.
38,782 PostsLatest Activity: Sep 02, 2026
