carringb
Mar 01, 2020Explorer
If you are getting condensation from your propane durnace, GET IT SERVICED ASAP! This is not normal, and indicated a cracked burner compartment.
As for better dash heat... there are many supplemental diesel-coolant heaters on the market, and can supply heat when parked if you add the electric water pump option.
38,782 PostsLatest Activity: Sep 02, 2026
