"quote"
( I can't guaranty this will remedy your situation and, I need to know what model of radio you have. If it's a Magnadyne, it may have a reset pin on it. Ours does. The reset button/pin is in between the two rotational dials, on the left side. It's slightly to the right of both of them. Ours did exactly what yours is doing, only about 5 years ago. I pushed that reset button/pin and, it came back to life and, has been working great ever since. Our coach is an '04 Itasca Horizon, 36GD with the C-7 330HP CAT.)
Scott
Hey, my reset button is not in the same place as yours. but I did punch it and the radio worked twice then quit again. I will play with it some more and see if it makes any difference.
Thanks for the info.
