tderonne
Nov 21, 2016Explorer
dougrainer wrote:
That is NOT a Blend door in the sense I am talking about. What THAT door does, it allows outside air to flow over the evap/heater core. When on MAX AC, that door closes and allows inside air to recirculate to allow more colder air. When that Blend door is OPEN, it allows outside air to then be heated or Cooled depending on what you pick. But that door does not reroute already heated or Cold air like in a Auto. Doug
Yes, it is a blend door ("DOOR - BLEND AIR" in Winnebago speak). The recirculation door ("DOOR - RECIRCULATION") is item #13. It's controlled by a vacuum servo, item #16. The blend door is controlled by a servo, item #22.
