CA_Traveler's avatar
CA_Traveler
Explorer III
Jun 09, 2020
Solar Controllers PWM MPPT Temperature Performance
It’s often stated that PWM performs better than MPPT up to 10% at higher temperatures which is a statement that’s largely out of context and basically incorrect. For anything other than for simple solar arrays the performance of the two controllers is the same.
I certainly agree that if you only only consider the panel temperature coefficients panel voltage goes down with increasing temperature and vice versa. The current changes but by by a much smaller percentage. I guess this is the source of the misinformation.
Increasing temperature moves the maximum power point down (less power) and to the left (less voltage) and the IR curve also shifts to the left. This results in decreasing power available for charging and at both lower temperatures and higher temperatures MPPT has the advantage.
IN 2014 when I was gearing up for solar I didn’t fully understand the issue which is explained in the “Victron White Paper Which solar charge controller: PWM or MPPT?”. If interested the document is not long or deeply technical. Enjoy
Click here: https://www.victronenergy.com/blog/2014/07/21/which-solar-charge-controller-pwm-or-mppt/
Then just under the Victron controller picture click on the link to download the pdf file.
