kickstart's avatar
kickstart
Dash wiring
I have a 1998 Damon intrude, does anybody know if you can lift the dash to get to the wiring and fuses or do you have to remove the captain's chair and lay on your back to get to everything.thanks for the help
  • Executive,thank you for your reply but mine doesn't have this option,my only other choice is taking out about 25 screws on the dash face and removing it
  • Usually there's a way to drop down from above. Mine has an inspection plate held on with four screws. They have upholstered covers on the screws which have to be popped off with a flat blade to access the screws. Look for an irregularity on the dash. Hopefully yours will have one. I'd hate to play houdini to look at the wiring...Best of luck...Dennis
