Cbmbdm's avatar
Cbmbdm
Dashboard gauges failure
Hit big bump, heard something start bumping around under passenger side feet. At same time lost speedometer, gas gauge, tach, oil press, engine temp trans temp. Is there a module that may have fallen off/out. Thanks
  • Ok that helps. I would check to see if something moved and unplugged the plug to the cluster.
  • dodge guy wrote:
    Is this a Class B van or a Diesel Pusher. Need some more info.
    YUP.
  • DrewE's avatar
    DrewE
    Explorer III
    It could also be a ground connection that broke/bounced loose, or just a connector to the dashboard cluster.
  • Is this a Class B van or a Diesel Pusher. Need some more info.
  • Had something like that happen in the past with a motorhome. Hit a big bump and A/C quit and it was hot. Bump had dislodged a fuse. Pushed back in and all ok.
  • You may have a fuse box/electrical panel under there that needs to be checked.
