chasfm11
Aug 30, 2012Explorer
Dash/Outer Frame Separation
Our 2000 Georgie Boy has an interesting but vexing problem. On our last long trip, I noticed that the dash was bouncing out of sync with the post at the back of the passenger side windshield. At times, the whole top of the dash would move different than fiberglass front cap. I was really nervous that a bad bump would loosen the bottom of the windshield.
When I got home, I opened up the passenger side of the dash. The metal in the "firewall" is robust and solid. There is no sign of broken welds or missing parts. From one of the pieces of channel steel, there was a fairly flimsy "L" bracket with three fairly thin screws that tied the dash to a panel that is an extension of the the material in the post along side the front door. There is nothing strong enough in that to provide any structural support. Two of the screws into the panel had been knocked out and were lying in the dash cavity and the remaining screw had been sheared off.
From underneath, all that I can see is the gap between the stepwell frame and the outer fiberglass. There was foam sprayed there that connected them but the bouncing has cracked it away. There is no sign of a structure support that has broken.
From the front, where the access to the genset and the house batteries is provided, it is a similar picture. There was foam sprayed in the passenger side corner at the joint between the dash and the front end of the panel that I can see inside and the fiberglass cap but it is all cracked and broken, clear to the center of the dash (it was sprayed along the front edge of the dash and there is no sign of any other connection between the dash top and the front cap fiberglass.)
There is no sign of stress or problems with the front cap itself outside. All the vibration is happening to the dash.
I suspect that there was a structural support fiberglassed to the front cap, right in front of the front entry door and by the front cap seam but short of opening that seam, I see no way to confirm that - or make a repair. I've considered buying or renting one of those remote camera setups with the probe that I can extend from the bottom or from the front and hoping that I can see something that way. Even if I can confirm my suspicions, I cannot imagine that making the repairs is a DIY job.
Questions:
1. Has anyone had a similar problem? Even if it wasn't a Georgie Boy, your experience might help me.
2. I'm a sailboat guy and am very familiar with fiberglass repairs. I can glass a piece of wood to the front cap that could be tied back into the frame. But I am somewhat concerned that if I don't get the loading point correct, my repair could damage the front cap and compound my problems. Am I just being paranoid?
I cannot physically move anything myself to try to recreate the failure statically. I'm assuming that this means that the forces involved are significant. As a result, I don't plan to drive the vehicle again except to take it to an RV body shop. I'm thinking that might be my only option.
All input is welcomed.
Charlie
Questions:
Charlie
