FIRE_UP
Jun 04, 2017Explorer
David0725 wrote:
Hi I am looking do replace my old day/night shades and was thinking of some different options. I would love to have a motorized rv shades. It dont have to be day/night. Or maybe even curtains. I dont want to spend alot on this project but would like something different. has anyone done this and what did you do? pic please if you have them. thank you!
Well, that's your first problem. Changing from the standard day/night shades to "Roller" shades, normally the brand MCD is the top of the line stuff, is not CHEAP. And, if you go motorized, it's even WAY more expensive. For instance, our bedroom window is about 30" wide by about the same tall. If I recall, MCD wants about $145 or so, just for that window and, it's a manual unit, not motorized. There are cheaper brands out there but, there's pitfalls with going cheaper.
Blind Chalet is another supplier. Theirs are quite a bit cheaper in the roller version of night/day. But, their mounting system is a lot harder to work with. MCDs use a clip system that's mounted then, you simply click in the entire assembly into those clips. If they need to come out for any reason, it's easy, just un-clip them.
But, Blind Chalet's units are screwed in. It's a lot harder to access the screws if, you have limited valance clearance that we do in our coach. But, again, they're about 1/2 the cost, and about the same quality. So, there's a couple of choices for you.
Scott
38,783 PostsLatest Activity: Sep 09, 2026
