Ed_Gee
Jun 14, 2015Explorer II
supercub wrote:
The cable side from the batteries of the fuse link is 10.5 volts. and the other side is of the fuse is 13.75 volts.
All AC in the couch is working fine.
Brian
If I understand your statement above ( and it was not crystal clear to me ) your fuse is OPEN. Also, at 10.5 volts your batteries are totally depleted and most likely have been severely damaged. . . probably will need replacing. The reason you have 13.5V on the other side of your fuse is because your battery charger/power supply is providing the DC voltage for your coach.
