Ivylog
Jun 14, 2015Explorer III
Measure the voltage on either end of the new cable. Is there any difference in voltage? You just proved you have a good conductor as both voltages are the same. YOUR FUSE IS BLOWN and that's the reason the voltages are not the same. It's cool to the touch because nothnig is happening.
I hope you are a better pilot than electrician.
