Hank_MI
Jun 14, 2015Explorer
supercub wrote:
I just used jumper cables and jumped across the fuse.......lights are bright etc etc. Voltage on both terminals is the same now at around 12.8 volts. Like many suggested, must be a blown fuse.......still not sure why I was getting continuity thru it.........maybe burnt away 95 of the fuse and left just enough to get continuity on my little meter.
Now, should I leave the cables hooked to see if I can charge up the batteries?
Glad you found the problem. Please read my previous reply regarding getting continuity.
