tropical36
Jun 14, 2015Explorer II
supercub wrote:
I can't keep the jumper cables hooked up, because the cables are getting hot. I assume it's because of high resistance due to poor conditions with the clamps. I disconnected them.
My next question is, if I run the generator, do you think that will charge my batteries up?
Thanks everyone for your input, sure did help.
Brian
Are ya sure all the polarities are correct and if you had a blown fuse, why so?
Is not your inverter or converter/charger working and you should be able to see the voltage difference with shore or gen power vs no charging assistance?
