Hank_MI
Jun 14, 2015Explorer
supercub wrote:
I can't keep the jumper cables hooked up, because the cables are getting hot. I assume it's because of high resistance due to poor conditions with the clamps. I disconnected them.
My next question is, if I run the generator, do you think that will charge my batteries up?
Thanks everyone for your input, sure did help.
Brian
Your batteries are charged by the converter/charger. It runs off 120vac, works the same on shore power or generator. I suggest removing the batteries and have them tested or at least remove the cables and try to charge each one individually.
