Hank_MI
Jun 15, 2015Explorer
Ivylog wrote:Hank wrote:
Your batteries are charged by the converter/charger. It runs off 120vac, works the same on shore power or generator.......try to charge each one individually.
In his first post he has four 6V batteries. As I suggested earlier disconnect one pair and charge one set at a time using your jumper cable around the blown fuse.
I didn't say it, should have, but I meant to use a battery charger to try and charge them not the converter. Most chargers have a meter and you can quickly tell if 1 of the batteries is taking a lot more amps than the others.
