cbr46
Jun 16, 2015Explorer
Dale.Traveling wrote:The bad cable crimp (and heat it generated) might have caused the fuse to blow before it reached it's rated value.
. . . why the fuse blew and I suspect if you replace it the new fuse will also blow with time. Doesn't need to be a dead short but you're seeing a heat build up that is slowing heating the lead in the fuse until it softens enough to melt ever so slightly as to open the circuit.
I'd replace the fuse, maybe even have a spare on hand, and give it some time with the new battery cable (which was IMO the original and only real problem).
Good luck,
- bob
