supercub
Jun 17, 2015Explorer
Problem is fixed. It was the fuse. Took it to Hendersons in Grants Pass, they had ordered the fuse for me. I got there a day early, so changed it myself. I'm running the generator (dry camping) and everything appears fine. Have the same voltage (13.7) on both sides of the fuse. Even after I took the fuse out, looking thru the little viewing window, it appeared to be ok. I checked the continuity and it was bad. Took the fuse apart and on one side out of view from the little window, it had gotten hot and melted a soldier joint. I'm going to have them load test the batteries in the morning just to make sure they're ok.
When I was having all this problem, as I mentioned prior, I turned on the generator and it was lugging down. Only ran it that way for a 1/2 minute. Now it's running fine too. Yes, they ordered two fuses so now I have a spare. This one was a 300amp, but I see I also have 100amp and 200amp fusable links. So I'm going to get spares for those too.
Thanks again for all the help.
Brian
Brian
