enblethen
Nov 20, 2014Nomad
It will give you some insight of whether wiring is good between battery and battery control center.
Battery control center is quite often located under the hood driver's side. There can be fuses there that protects the wiring coming from the converter which should charge your battery.
Locate your converter. Check to see if the converter has 120 volts AC to it. Then check output for at least 12 volts but closer to 13 volts output. This should be same voltage as arriving at the battery control center.
38,707 PostsLatest Activity: Jan 05, 2014
