ksg5000
Nov 20, 2014Explorer
MarineandAirforcevet wrote:
Kevin I know what u are referring to now and I have a few of them under the dash. I guess I will just replace them and get a new batt disco relay and see what happens
The auto reset circuit breakers are easy to test - just do a continuity test between the two lugs. There inexpensive and carry a spare might be a good idea.
If your getting power by disconnecting/bi-passing the battery disconnect solenoid that's likely the issue ... might be the fuses on top of the solenoid - might be a bad rocker switch connecting to the solenoid. Does the solenoid make a "click" when your press the rocker switch - if you press in one direction it cuts off power - pressing it in the other direction should reconnect the batteries.
38,707 PostsLatest Activity: Feb 28, 2025
