Harvey51
Mar 20, 2017Explorer
I'm in the same position as wbwood - I use the link antifreeze and in potentially freezing temperatures I would start out with antifreeze in the pipes until convinced it will be warm enough overnight. Warm enough for us is -10 C or 15 F with the furnace running to blow warm air at the pipe under the floor. Also it is most annoying when a sink drain pipe elbow under the floor freezes and cracks - if you must drain water, chase it with antifreeze when below freezing.
38,776 PostsLatest Activity: May 18, 2026
