pconroy328
Mar 21, 2017Explorer
ever1ast15 wrote:
Don't want to hijack this thread, but on the same topic. After you flush the pink stuff out of your RV, do you have to run bleach/water solution through to disinfect or can you just run clean water through several times and be OK to use the water?
Thanks James
clean water.
The "Pink Stuff" is non-toxic and usually contains propylene glycol. Which, if you've ever had Mountain Dew, doesn't taste too bad! ;)
If your RV Antifreeze doesn't use propylene glycol, they'll use Ethanol. Which, if you've ever had (insert long list of libations) also doesn't taste too bad! :)
38,776 PostsLatest Activity: May 18, 2026
