stepdad wrote:
Hey good folks,
We have a 2004 Winnebago Journey. It has new house batteries and the engine batteries we were told are good to go. I turn the key to start it and it's dead. No noise, no nothing. Dead. Any help will be appreciated.
~Thanks, John
Try the simple things first ie: is the shift pad neutral button pushed? 2,Try holding the battery boost button down while attempting to start main engine 3,check voltage at batteries with a vom should be about 12.5 volts dc. If voltage is not about 12.5 then determine reason bad battery or in need of charge. Check for loose or corroded connections at battery or starter. Check for bad ground.
Good Luck Don
