stubblejumper's avatar
May 10, 2013
Dead panel HWH Levelers
First I have read nearly all HWH posts on the forum and recognize Doug as the expert.
Have a 99 Winnie Chieftain F53 HWH Levelers series 200
Problem: Panel is dead, joystick is "floppy" when levers are in down position.
Park brake light is on, on the dash, Ignition is in either Acces position or engine is running. Fuse in panel is OK .
Also cannot locate reservoir in engine compartment. Have not crawled under due to spring thaw ( might drown :>)
Have tried email to HWH--- no response nearest dealer is 300 miles away.
All worked fine in fall when stored away (outside)
Any help would be appreciated THANKS
