Doug
1) Have no power to panel so if I by pass park brake switch by grounding wire on panel that goes TO park brake on the connector with the pigtail joining 2 connectors this should give me power to panel ... right ?
2) Joystick is straight levers.. no lights ... will open that and check grounds there.
Will get back to you with results
Thanks for your input.
Bumpy..
Know what you mean about mashing it.. But if I press any harder I will have to go for knee replacment. If I can solve problem as above will tackle tha damn switch from up top through the dash. Luckily I have a drivers door. Thanks
