rgatijnet1
Mar 26, 2015Explorer III
SuicideCharley wrote:
Carfax shows mileage history at each emissions test. Nothing whacky to note there so a true reading of the 72K. Ran it through its paces and everything is in working order without any leaks from any of the tanks. Tires are beyond the 7 yr old mark, the dash AC works really weird (blows through bottom vents and not through tops) but I think it's something I can handle. Visual of all lines I could see seem to be ok. No fluid leaks from the motor or tranny. Generator couldn't be fired up because of missing batteries.
The tow behind vehicle runs like a top and is virtually NEW inside. 137k on the dial but you wouldn't know by how it runs. Tires needed for that one too.
Left a deposit, pick up today! If everything goes well the family and I will take it out on a short run Easter weekend! Appreciate all the input!
The AC ducts are probably controlled by engine vacuum. If the vacuum lines are original they have hardened and are probably leaking. You can buy bulk vacuum hose at any auto parts store and change then all for less than $20.
