Executive45
Sep 20, 2015Explorer III
Contact Wholesale Warranties for a quote BEFORE you make a decision. In YOUR situation, these guys suggesting you put $4k in the bank is laughable. I am pretty mechanically inclined and I'm on my SECOND service contract. Yes, you must be diligent on looking over the contract carefully. Jeff Shelton is the owner of WW and is accessible over the phone. He will explain the contract fully to you BEFORE you purchase. My first contract was paid for by the dealer, thru negotiations. They replaced the rear end in my coach at a cost that exceeded $4k. They replaced the cooling unit on my Norcold, $2k. My second contract thru WW has replaced one of my 15,000btu heat pump A/C, $2k, one of my tires that blew when I ran over a piece of steel, $750, replumbed the kitchen sink because of a design flaw with the slide mechanism, $2k, repaired the engine turbo when it came loose, $1500 and replaced a couple solenoids for the step cover, door seal and air horns. So, I'm one of those that has benefited from the contract and YES we are full timers, using the coach a lot. 86,000 miles so far. The "trick" in using these contracts is they require you to jump thru certain hoops to get proper service. Most people don't or won't jump thru those hoops. You MUST get prior approval BEFORE any work is done. When my A/C unit failed, I had a mobile tech come to the cg, determined the unit was no good, obtained approval, ordered the unit, had it delivered to the CG, returned and installed it on site. All within a weeks time. I did pay an additional charge for expedited delivery. My choice.
I believe in the service contract for, like you, peace of mind while traveling. While some of these things could be fixed yourself, $1k a year is cheap insurance....just sayin....Dennis
