looking for the easiest method to remove original grahics (decals)from fiberglass rv. currently using the hairdryer/blade method. very time consuming with low productivity
If you use a heat gun, keep the heat low and use it just long enough to soften the decal. Too much heat can affect the glue used in the construction process and lead to the sidewall becoming delaminated. A hair dryer works the best, and is the safest for decal removal. It is not an easy process but they can be removed, usually in pieces.
