I've used the one you bought for the last 6 months. I don't know why I waited 9 years of full timing to finally break down and buy one. Like you, I did a lot of research and found that it doesn't matter much how big the tank is, 3 gallons is fine, its the CFM at 90 lbs that makes things come together. 2.6 cfm is about the highest rate you will find in a small portable compressor. That works just fine. The 150 cut-off is a definite plus when you need 105 lbs of air in that MH tire.
I leave mine in the bay and just plug it in when necessary and run the hose to the tires to inflate.
I couldn't be happier, I know you will be too.
BTW: With being ex-military, you get another 10% off of any purchase at Lowes....they treat vets right.
