Bought the Kobalt at Lowe's. The floor model looks well made and solid. The Kobalt max pressure is 155, and is suppose to cut in at 120.
Neither Lowe's or Home Depot had the accessory kit I wanted, so settled for a less expensive one, which had ok reviews.
I did opt for the rubber hose that can be repaired, Lowe's was out of stock, but HD carried one.
Oh, both Lowe's and HD honored the Veterans discount, which further reduced the cost of the compressor and accessories by 10 percent. Thanks Lowe's and HD.
Will probably put it to its test over the next couple of days, bringing the MH tires up to 100 psi.
