want-a-be's avatar
want-a-be
DEF Filter
Was wanting to know if there is a DEF Filter on a Freightliner Chassis and if there is where is it located!
Thanks for all comments!
  • Ivylog wrote:
    Your 2013 has one located upstream from your exhaust tip...it will look like a muffler BUT it has wires coming out of it.
    You are referring to the selective catalytic reduction unit, not the DEF filter. It's on or near the DEF tank.
    I believe you are referring to the DPF (diesel particulate filter). The OP is speaking of a filter for the DEF liguid fluid.
  • On our 2013 Freightliner chassis, the DEF filter is located on the bottom of the DEF tank assembly. No wires are connected to it and it is easy to replace.
  • Ivylog's avatar
    Ivylog
    Explorer III
  • JoeH's avatar
    JoeH
    Explorer III
    On my 2013 the DEF filter is located by/below the DEF tank. I think the filter is good for 500,000 miles, but I went ahead and changed it anyway a few months ago.
