rv4jimnme's avatar
rv4jimnme
DEF Tank SCR 2011 Fleetwood Tioga Ranger 24L MB Sprinter
Everything about Diesel is new to us. We now understand that the rather large looking tank located next to entrance door in lower compartment holds DEF. Part of the Maintenance prior to buying this Coach was to fix engine check lite codes 106200. It states lower limit value of long term adaption of scr system was dropped below. Test DEF fluid - passed- removed EDF injector and clean. also previous code for fuel rail pressure caused by fuel filter. Fuel Filter changed.
The tank has obviously been painted high gloss black which I am assuming is for ascetic value and not a rust problem(?) and white "stuff is bubbling up and dripping a bit from the cap. I believe DEF does turn white? Just wondering if perhaps this can become an Issue? Also am curious about the amount of DEF and the weight. I would assume one has to add that figure when determining over all load capacity just like holding tanks, fresh water. The Dealer records appear to be from a reputable Mercedes Establishment and look complete. I have no reason to question the veracity its just that I don't understand mechanical issues and am totally clueless on Diesel Engines. So in simple terms please. and Thanks
