et2's avatar
et2
DEF tank size
We have a new 2013 Fleetwood Expedition. I thought the DEF tank was suppose to be 5 gallons. It read at the dash and the tank gauge half full. I added 2.5 gallons and it only came up to 3/4 full.
I checked for the tank size in the manual and its not mentioned where I can see. Anyone know? Based on that, it sounds like 10 gallons.
  • robatthelake wrote:
    DEF is Not Fuel so it has no bearing on Mileage!
    What it does is clean the Exhaust system and reduce pollution.
    But there is still a mileage factor to it. You consume the DEF over time and miles. Like I stated, I go about 1100 miles on one gallon of DEF. AT that rate, I could go about 5500 miles on one five gallon tank of the stuff.
  • DEF is Not Fuel so it has no bearing on Mileage!
  • On my Ford, the tank is five gallons. When it said it was 1/2 empty, I bought a 2-1/2 gallon container and poured it in. It took all of it. Then, the next time when it was showing 1/2 full, I put the same amount in, and it was full after only 3/4 of a bottle. I think the gauges/monitors on the DEF tank are about as accurate as the gauges on your typical RV black tank. On the good side of things, I'm getting about 1100 miles per gallon on my DEF.
  • What chassis?? Our Journey has a Freightliner chassis and it has a 10 gl. tank
