BlueMaxOhio
Mar 31, 2014Explorer
Spizzer wrote:
Am I understanding this right? The windshield is on the outside of this metal frame, so outside water is not the issue, but condensation running down the inside gets between the glass and metal?
Thanks, jeff
It's and outside and inside water problem. On the upper part of the frame, water can seep in between the glass/sealer and the frame. This would be outside water. The bottom of the frame, though is covered by the same black rubber molding and can be exposed to water. I however believe the problem occurs when water gets trapped from inside condensation. It makes no difference if it comes from outside or inside, it stills rusts.
