DiskDoctr
Aug 14, 2017Explorer
If you get a cap with the hose fitting on the end of it, get a threaded PVC tee to mate (not sure of the size?) and add some glue to the threads to install the tee, like this one (check the size!)
This is a good site, but watch the shipping for small orders: PVC Fittings
Then you can use a piece of pipe, broom handle, whatever you want to stick in the tee to remove or install.
You might want to plug up the hose fitting with glue, plastic, a plug, whatever, so your cap won't be open to atmosphere.
FYI. Be careful as the cap might be a hose fitting, requiring and adapter, or just use a smaller die, grind off the threads, or whatever- you're going to glue the fitting on anyways ;)
Hope this helps!
Hope this helps!
