hipower wrote:
hostage wrote:
hipower wrote:
I understand your problem with hand strength and suspect that many of us will encounter the same thing at some point.
The wrench you suggested is nothing sophisticated and simply a plastic spanner wrench. I found them at several places for $5.75 and up. For that kind of money I'd buy two. One to use and one to use as a pattern for a machinist to make me one out of aluminum if I was afraid of breaking the first one. If I was going to have one made I'd probably extend the handle a little depending on my space available when using it. Not because I think the extra leverage would be needed, just because it may be and it wouldn't add to the cost significantly.
The bad side of that thinking is you would probably have $100 invested in a wrench that you could replace 15-20 times for the same money in the plastic ones.
rhino come as a pair @12$ left and right as in on and off
The logic of that escapes me. On or off would be simply controlled by the wrench placement on the fitting wouldn't it?
beats the hell outta me? I just saw it was two wrenches for 12$ and thought with the grooves and the way they grip there may be one for install and one removal
