dennislanier
Aug 18, 2015Explorer
Hiker_01 wrote:fla-gypsy wrote:
The vehicle maker gives you the psi to use based on the OEM tires. They cannot possibly fathom what each owner will replace those OEM tires with and makes that information invalid once the OEM tires are replaced unless replaced with the identical tire in every respect. Come on and lets think a little please. No vehicle maker is sticking their neck out on replacement parts obtained by the end user. Once the OEM tires are replaced use the tire makers inflation chart. Holy moly sometimes I just SMH.
Concur. Info on our trailer says to inflate tires to 80 psi, but tires that are currently on trailer says 50 psi max. My guess is somewhere along the line someone changed out tires, so definitely going to go with tire rating, not what is on trailer.
While I agree with you in this case to go with the Max PSI ON THE TIRE, I wonder if these replacement tires are "heavy-duty" enough for your trailer. Not making a statement - just asking.
38,771 PostsLatest Activity: Apr 14, 2026
