CapriRacer
Aug 18, 2015Explorer II
fla-gypsy wrote:
The vehicle maker gives you the psi to use based on the OEM tires. They cannot possibly fathom what each owner will replace those OEM tires with and makes that information invalid once the OEM tires are replaced unless replaced with the identical tire in every respect. Come on and lets think a little please. No vehicle maker is sticking their neck out on replacement parts obtained by the end user. Once the OEM tires are replaced use the tire makers inflation chart. Holy moly sometimes I just SMH.
Not exactly.
ALL tires are standardized - especially those that fit on a Class C motorhome. It does NOT matter who manufactures the tire, the tire is designed to the same load table.
Both the vehicle manufacturers and the tire manufacturers reference the same tire standards, so what the vehicle manufacturers put on the vehicle tire placard will be applicable for ALL tire manufacturers, not just the original tires - unless, of course, the vehicle manufacturer screws up, then all bets are off. (It has been known to happen, and the vehicle should be recalled to fix it!)
38,771 PostsLatest Activity: Apr 14, 2026
