Chum_lee
Jan 08, 2020Explorer
95impala wrote:
Does anyone have experience with this air compressor, I am trying to downsize from my big heavy pancake compressor for traveling.
IME/IMO you would be best sticking with what you already have (120 Volt pancake style) and finding/making a place to stow it. For RV's, you need higher pressures than for most automotive applications. The tires are larger and require more air volume at higher pressures. I've yet to see a rechargeable portable/compressor that is up to the task for anything other than a once in a lifetime emergency. So far I have melted two different 12 volt compressors when using them on my Class A which requires 90 psi.
I bought one compressor at Walmart for +-$40.00. It said on the box it was capable of generating "up to" 140 psi. When I returned it to customer service a week after buying it, the clerk asked me, "Sir, what is your reason for the return? I smiled, opened the box (a burned plastic/electrical smell wafted over the clerk) and I said, "I don't think this is going to work out." The clerk cringed at the smell, . . . . . . . then returned my money. NEXT! Enough said.
Chum lee
38,783 PostsLatest Activity: Sep 09, 2026
