grampscamper wrote:
mikeak wrote:
Water pours out through drain valve by the back wheel.
Is there any chance this is a low point water drain that needs to be closed?
OK...once I did hook up, go inside to open faucets, remove air from lines, pressurize system, turn on water heater. It was taking forever to get the air out of the lines...wife says: "there is a bunch of water leaking under the trailer". I run outside wondering what line busted......YEAP.......both drains wide open :S
OP... My low point drain once got stuck open. The valve was closed (for me it is under my bed near the tank), but water still poured out. I had to go under the trailer and stick a tiny screw driver up into the drain hose. I think that plastic little valve was twisting, not allowing the rubber bushing to seat firmly. Poking at it allowed it to "un-twist" and seat correctly.
