christsong1's avatar
christsong1
Dextron 3
I'm 90% sure about this but I want to be certain.In the rear engine compartment, there's a reservoir that I believe to be for the transmission. It says,"hydraulic reservoir.Fluid Only. Dextron3 or equivalent." This is what Car Quest said took the place of original.
  • We have a large vertical tank, in rear compartment near engine. It uses trans fluid. It is for the jacks. Reminds me, it probably would be a good idea to change it.
  • X2 on the power steering and or hydraulic fan. Need to know what make of coach you have to get a better idea, thay are not all the same. Mine uses Dextron3 for the fan and steering.
    JR
  • Yes that will work.I doubt it is for the transmission more likely reservoir is for power steering or hydraulic fan .
