DrewE
Oct 25, 2016Explorer III
Campfire Time wrote:
This is the reason I not only blow out the lines, I use antifreeze in them as well.
You're certainly welcome to do that.
However, I must say I am a bit puzzled by how you're less likely to forget to pump antifreeze out the low point drains than you are to forget to pump air out the low point drains when winterizing. Failing to do either one would seem to me to be approximately equally problematic.
38,771 PostsLatest Activity: Apr 15, 2026
