From a financial perspective....
I feel diesels pay back when driven. If you don't drive your motor home that much, then the investment payback won't happen, most predominantly with a Mercedes Sprinter.
There are a few other factors some people tend to overlook with a Sprinter or Transit diesel.
1) They are usually equipped with a propane generator because it is cheaper and lighter than the diesel version....propane is a hot commodity in remote areas of the country, especially in spring and fall when running your furnace.
2) The Sprinter (not sure about the Transit) you cannot idle the engine for extended periods, a limitation of it's emission systems. For me, I find comfort knowing I can idle our gas engine as much as I desire for back-up heat, cooling, battery charging, and during generator restrictions.
3) Sprinter-specific, maintenance and service is costly and limited.
But as others are sharing, the Sprinter and Transit are simply attractive and comfortable. You prioritize what is right for you, and be happy.
