Crazy Ray wrote:
GET V10
There is a lot more to deciding to get a DP (OR NOT) than just the engine. Granted if it only has the little Cummins 5.9 engine (older ones had dowel pin problems) and as a previous thread said: "the insides look like a travel trailer" there is not enough difference to go diesel.
In the past a V10 could handle a max of 36' of MH (yes I know there were a few longer). Today you are seeing it in 38' units, but longer/heavier than that you need a 7.2L DIESEL engine or BIGGER (Yes, I know there are some with Cummins 6.7... a good little PU engine).
Normally in a 38' or bigger DP you are getting more than just a quieter ride (without adding Dynamat), air brakes, and air ride suspension... you should be getting a much better built rig with solid wood cabinets, tile, Corian, four slides............ and good handling without adding track bars, steering stabilizers, upgraded shocks, bigger sway bars......... and you get a 10K hitch.
